bu da benden olsun ibiza/cordoba vag-com kodları ama ne işe yaradıklarını bilmiyorum biraz araştırdım neten ama bulamadım 2002+ için (6L)
00277 ABS Inlet or Outlet Valve - Left Front (N137)
00278 ABS Main Valve (N105)
00279 Differential Lock Valve 1 (N125)
00280 Differential Lock Valve 2 (N126)
00281 Vehicle Speed Sensor -No Signal (G68)
00282 Throttle Position Actuator -V60
00283 P1711 ABS Wheel Speed Signal #1 (Left Front) - Range/Performance -G47
00284 ABS Inlet or Outlet Valve - Right Front - N138
00285 P1716 ABS Wheel Speed Signal #2 (Right Front) -Range/Performance - G45
00286 ABS Inlet or Outlet Valve - Left Front -N139
00287 P1721 ABS Wheel Speed Signal #3(Right Rear) -Range/Performance (G44)
00289 ABS Inlet or Outlet Valve - Right Rear (N140)
00290 P1726 ABS Wheel Speed Signal #4 (Left Rear) - Range/Performance. (G46)
00291 Pressure / Fluid Level Warning Switch (F116 / F117)
00292 Hydraulic Energy Supply Pressure Level
00293 P0705 Multi-Function Transmission Range Switch - Malfunction (PRNDL Input) (F125)
00294 Transmission Pressure Switch L (F174)
00295 Transmission Pressure Switch 2 (F175)
00296 P1704 Kick-down Switch - Short to ground (F8)
00297 P0715 Input/Turbine Speed Sensor Circuit - Malfunction
00297 P0721 Vehicle Speed Sensor Circuit - Range/Performance -Signal Noisy (G38)
00297 P0722 Vehicle Speed Sensor Circuit - No Signal
00297 Transmission Vehicle Speed Sensor (G38)
00298 Rear Differential Lock Switch -E121
00299 Transmission Shift-Range Program Switch -Short Circuit -E122
00300 P0712 Transmission Fluid Temperature Sensor Circuit Low Input (G93)
00300 P0713 Transmission Fluid Temperature Sensor Circuit High Input (G93)
00301 ABS Return-flow Pump (V39)
00302 ABS Solenoid Valve Relay (J106)
00303 Board Computer Function Selector Switch (E91)
00305 Fuel Consumption Indicator Signal
00306 Secondary Air Injection - Cylinder Bank 1
00307 Secondary Air Injection - Cylinder Bank 2
00309 Cleaning Solution Metering Pump (V135)
00310 Catalytic Convertor Temperature Sensors (G20)
00312 Catalytic Convertor Control Temperature Sensors (G132)
00313 Three Way Catalytic Converter -Signal Malfunction
00314 EGR Two Way Valve (N161)
00447 ABS-ASR Motor -Electrical Connection 2
00501 Central Flap Motor Position Sensor -G92
00512 P0341 Cam Sensor -Signal Error
00512 Camshaft Position Sensor - Not on Reference Mark
00513 P0506 Engine Speed Sensor -G28 -Idle RPM Too Low
00513 P0507 Engine Speed Sensor -G28 -Idle RPM Too High
00513 Engine Speed Sensor -G28 -Signal Malfunction
00514 P0336 Crankshaft Position Sensor -Erratic Signal - G4
00514 Crankshaft Position Sensor -G4
00515 P0340 Camshaft Position Sensor (Hall Effect Sensor) -No Signal (G40) : Check CMP, if
00516 Throttle Position Sensor -Closed Switch -F60
00517 Throttle Position Sensor -Wide-open Switch -F81
00518 P0121 Throttle Position Sensor -Signal Out of Range (G69) Also check for loose ECM power relay.
00519 P0106 MAP Sensor -Out of Range -G71
00519 P0107 MAP Sensor -Voltage Low -G71
00519 P0108 MAP Sensor -Voltage High -G71
00520 Volume Mass Air Flow Sensor -G19ig70
00521 Co Fuel Trim Potentiometer -G74
00522 Engine Coolant Temperature Sensor -G62
00523 P0112 IAT Sensor - Temp High -Circuit Low - G42
00523 P0113 IAT Sensor - Temp Low - Circuit High - G42
00524 Knock Sensor 1 -G61
00525 P0131 O2 Sensor -Voltage Low -G39
00526 Brake Light Switch -Incorrect signal (F)
00527 Intake Air Temperature Sensor -G72
00528 Barometric Pressure Sensor -F96
00529 P0725 Engine Speed Input Circuit (RPM Sensor) - Malfunction. Also check for loose ECM power relay.
00529 P0727 Engine Speed Input Circuit (RPM Sensor) –No Signal
00530 Throttle Position Sensor -G88
00531 Mass Air Flow Sensor Reference Voltage
00532 P1746 Transmission Control Module Relay - Supply Voltage (B+) Malfunction Low Battery or Bad Ground
00532 P1750 Supply Voltage (B+)
00533 Idle Air Control Regulation
00534 Oil Temperature Sensor -G8
00535 First Knock Sensor
00536 Second Knock Sensor
00537 Oxygen Sensor Control
00538 Reference Voltage
00539 Fuel Temperature Sensor -G81
00540 Knock Sensor 2 -G66
00541 Slide Travel Sensor -G99
00542 Needle Lift Sensor -G80
00543 P0726 Engine Speed Input Circuit - RPM Upper Limit Exceeded
00544 Maximum Charge Air Pressure Exceeded
00545 P1780 Engine Intervention Unreadable. Also check for loose ECM power relay.
00545 P1781 Engine Intervention Stuck Off. Also check for loose ECM power relay.
00545 P1782 Engine Intervention Stuck On. Also check for loose ECM power relay.
00546 Data Communication Line Faulty
00547 ABS Pressure Control Switch -F137
00548 P0560 System Voltage Malfunction
00549 Fuel Consumption Signal
00549 P1771 Load Signal Stuck Off (RPM Signal missing)
00550 Injection Start Control
00551 Catalytic Convertor Excess Temperature
00552 Volume Air Flow Sensor (Position Sensor) -G19
00553 Mass Air Flow Sensor -G70
00554 Oxygen Sensor 2 - Control
00555 Heating Circuit - Oxygen Sensor 2 -G108
00558 Mixture Control Adjustment Limit - Lean Position
00559 Mixture Control Adjustment Limit - Rich Position
00560 EGR Temperature Sensor Switch Short or Implausible Value
00561 Mixture Adjustment Control
00575 Manifold Absolute Pressure Sensor
00577 Knock Sensor Control -Cylinder 1
00578 Knock Sensor Control -Cylinder 2
00579 Knock Sensor Control -Cylinder 3
00580 Knock Sensor Control -Cylinder 4
00581 Knock Sensor Control -Cylinder 5
00582 Knock Sensor Control -Cylinder 6
00583 Knock Sensor Control -Cylinder 7
00584 Knock Sensor Control -Cylinder 8
00585 EGR Temperature Sensor -G98
00586 EGR System Control
00587 Mixture Control Adjustment Limit - Bad ECU ground, Air leak, Leaking Injector.
00588 Air-bag Ignition Circuit - Driver Side -N95
00589 Air-bag Ignition Circuit 1 - Passenger Side -N131
00590 Air-bag Ignition Circuit 1 - Passenger Side -N132
00591 Seat Belt Tensioner Switch - E24
00592 Seat Smelt Tensioner Switch - E25
00593 Seat Detect Switch - Passenger Side -F151
00594 Air-bag Ignition Circuit
00595 Crash Data Already Stored
00596 Injector or Trans. Solenoid Wires - Short
00597 P1728 Varying ABS Wheel Speed Signals -Range/Performance
00598 Hydraulic/Mechanical Malfunction
00599 Possibility-pressure Brake Light Switch
00600 Temperature Regulator Flap Motor Position Sensor -G92
00602 Foot-wall/defroster. Flap Motor Position Sensor -G114
00603 Foot-wall/defroster Flap Motor -V85
00604 Back Pressure Flap Motor Position Sensor -G113
00605 Fresh Air Recirculation Flap Two-way Valve -N63
00606 Engine Coolant Two-way Valve -N147
00607 Outside Air Temperature Display -G106
00608 Load Sensor -G119
00609 Ignition Output 1
00610 Ignition Output 2
00611 Ignition Output 3
00612 Ignition Output 4
00613 Ignition Output 5
00614 Ignition Output 6
00615 Ignition Output 7
00616 Ignition Output 8
00617 Air-bag Deceleration Sensor -Left -G104
00618 Air-bag Deceleration Sensor -Right -G105
00619 Sensor Supply Line - Left
00620 Sensor Supply Line - Right
00621 Pressure Reduction Valve -N155
00622 Draining Water from Fuel Filter
00623 ABS/Transmission Electrical Connection
00658 Operating Module
00659 Self Test
00660 Kick-down Switch / Throttle Position Sensor
00661 Temperature Indicator
00662 Tachometer -G5
00663 Speedometer -G21
00664 Fuel Gauge
00665 Seat Belt Warning Light -K19
00666 Signal
00667 Ambient-temperature Signal
00668 Battery Power Voltage Supply (Terminal 30)
00669 Secondary Mil -K97,
00670 Throttle Position Sensor -G127
00671 Cruise Control Switch -E45 - Undefined Switch Position
00672 ABS Hydraulic Pump with Series Resistance
00673 Brake Pedal Pressed
00674 Brake Released
00675 IV-Left Front: OV OV-Left Front; OV - Left Front Wheel Locked
00676 IV-Left Front: B+ OV-Left Front: OV - Left Front Wheel Locked
00677 IV-Left Front: B+ OV-Left Front: B+ -Left Front Wheel Free
00678 IV-Left Front: B+ OV-Left Front: OV - Left Front Wheel Free
00679 Oxygen Sensor Heating Circuit in Front of Catalytic Convertor
00680 IV-Right Front: OV OV-Right Front: OV - Right Front Wheel Locked
00681 IV-Right Front: B+ OV-Right Front: OV - Right Front Wheel Locked
00682 IV-Right Front: B+ OV-Right Front: B+ -Right Front Wheel Free
00683 IV-Right Front: B+ OV-Right Front: OV - Right Front Wheel Free
00684 Oxygen Sensor Heating Circuit. Behind Catalytic Convertor
00685 IV-Left Rear: OV OV-Left Rear: OV - Left Rear Wheel Locked
00686 IV-Left Rear: B+ OV-Left Rear: OV - Left Rear Wheel Locked
00687 IV-Left Rear: B+ OV-Left Rear: B+ -Left Rear Wheel Free
00688 IV-Left Rear: B+ OV-Left Rear: OV - Left Rear Wheel Free
00689 Outside Air in Intake Air System
00690 IV-Right Rear: OV OV-Right Rear: OV - Right Rear Wheel Locked
00691 IV-Right Rear: B+ OV-Right Rear: OV -Right Rear Wheel Locked
00692 IV-Right Rear: B+ OV-Right Rear: B+ - Right Rear Wheel Free
00693 IV-Right Rear: B+ OV-Right Rear: OV -Right Rear Wheel Free
00694 Switch and Instrument Lighting
00695 Hydraulic Pump (B+) -Left Front/right Front Wheel Looked
00696 ABS Pressure Reducing Valve. -N170
00697 ABS Pressure Reducing Valve. -N171
00698 Control Module Increased Current Consumption
00699 Oxygen Sensor I - Behind Catalytic Convertor -G130
00700 Oxygen Sensor 2 - Behind Catalytic Convertor -G131
00701 ECT Overheat Test
00702 Flexible Fuel Sensor -G133
00703 CTP Recognition TPS/CTP Switch
00705 Coolant Fan Switched on
00709 Sunlight Photo Sensor 2-g134
00624 A/C Compressor Engagement
00625 Vehicle Speed Signal
00626 Glow Plug Indicator Light -29
00627 Water Level Sensor -G120
00628 Actuating Variable Control
00629 Vacuum Vent Valve - Brake -F47
00630 A/C Switched on
00633 Wiring to Ignition/sensor for Delay
00634 Series Resistance -N159
00635 Oxygen Sensor Heating Circuit -Ahead of Catalytic Convertor
00636 Acceleration Sensor -Right Front - G121
00637 Acceleration Sensor -Left Front - G122
00638 P1766 Throttle Angle Signal - Stuck Off. Also check for loose ECM power relay.
00638 P1767 Throttle Angle Signal - Stuck On. Also check for loose ECM power relay.
00638 Engine/Transmission Electrical Connection 2. Also check for loose ECM power relay.
00639 Deceleration Sensor -G123
00640 Oxygen Sensor Heating Relay -J278
00641 ATF-Temperature too High
00642 EDL Switch-over Valve - Right Front - N166
00643 EDL Outlet Valve - Right Front -N167
00644 EDL Switch-over Valve - Left Front -N168
00645 EDL Outlet Valve - Left Front - N169
00646 ABS-ASR Motor -Electrical Connection 1
00648 Oxygen Sensor Heating Circuit -Behind Catalytic Convertor
00649 ABS Inlet/outlet Valve - Rear -N160
00650 Clutch Vacuum Vent Valve Switch -F36
00651 Ignition Wiring
00652 P0730 Transmission Shift-Range Controller -Incorrect Gear Ratio
00652 P0731 Transmission Shift-Range Controller -Gear #1 -Incorrect Ratio
00652 P0732 Transmission Shift-Range Controller -Gear #2 -Incorrect Ratio
00652 P0733 Transmission Shift-Range Controller -Gear #3 -Incorrect Ratio
00652 P0734 Transmission Shift-Range Controller -Gear #4 -Incorrect Ratio
00653 Automatic Transmission Selector Lever
00654 Seat Belt Tensioner Igniter 1 -N153
00655 Seat Belt Tensioner Igniter 1 -N154
00656 Air-bag Seat Detect Sensor -G128
00657 Center Vent Adjusting Motor -V102
00710 Defroster Flap Motor -V107
00711 Left Foot Well Flap Motor -V108
00712 Right Foot Well Flap Motor -V109
00713 Left Center Vent Motor -110
00714 Right Center Vent Motor -V111
00715 Rear Foot Well Vent Motor -V112
00716 Recirculation Flap Motor -V113
00717 EVAP Flap Motor -V114
00718 Upper Left Vent Switch -F179
00719 Upper Right Vent Switch -F180
00720 Lower Left Vent Switch -F181
00721 Left Right Vent Switch -F182
00722 Left Center Vent Switch -F183
00723 Right Center Vent Switch -F184
00724 Left Center Foot Well Vent Switch -F185
00725 Right Rear Foot Well Vent Switch -F186
00726 Center Rear Foot Well Vent Switch -F187
00727 Defroster Flap Motor - Position Sensor -G135
00728 Left Center Vent Motor -Position Sensor -G136
00729 Right Center Vent Motor -Position Sensor -G137
00730 Center Vent Motor - Position Sensor -G138
00731 Left Foot Well Flap Motor -Position Sensor -G139
00732 Right Foot Well Flap Motor - Position Sensor -G140
00733 Rear Foot Well Left Vent Motor -Position Sensor -G141
00734 Center Vent Position Sensor -G142
00735 Recirculation Flap Position Sensor -G143. * If this code is found on late model VR6 (AAA) refer to code #01247.
00736 EVAP Flap Motor. Position Sensor -G144
00737 Left Heat Regulating Valve -N175
00738 Rear Heat Regulating Valve -N176
00739 Coolant Pump -V50
00740 Cylinder 1 CKP Sensor -G145
00741 Brake Pedal Position Status Monitoring
00742 Battery Ventilation System
00743 Battery Ventilation Sensor -G146
00744 Battery Temperature Regulation
00745 Insulation Status Monitoring
00746 Battery Cell Failure
00747 Front Battery Temperature Sensor -G52
00748 Rear Battery Temperature Sensor -G53
00749 Ventilation Flap
00750 Fault Lamp Circuit
00751 Battery Capacity Indicator
00752 Fan and Battery Heating
00753 Electrical Connector - Wheel Speed Sensor
00754 ECT Warning Light
00755 Engine Oil Pressure Warning Light -K3
00756 Left Vent Temperature Sensor -G150
00757 Left Vent Temperature Censor -G151
00758 Secondary Air Injection System (Air)
00759 Left Vent Temperature Regulator -G155
00760 Right Vent Temperature Regulator (Actuator) -G156
00761 Diagnostic Trouble Code Stored in Control Unit
00762 Fuel Injector(s) -N181
00763 Driver Side Gas Pressure Sensor -G147
00764 Passenger Side Gas Pressure Sensor -G148
00765 Slide Control Travel (Piston Displacement) Sensor -G149
00766 Front Vent Temperature Sensor -G12
00767 Rear Evaporator Temperature Sensor R-g153
00768 Rear Heater Core Temperature Sensor -G154
00769 Engine Coolant Temperature Sensor -G82
00770 Engine Coolant Temperature Sensor -G83
00771 Fuel Level Sensor -G
00772 Oil Pressure Switch -F22
00773 Oil Pressure Sensor -G10
00774 Level Control System Sensor - Left Rear - G76
00775 Level Control System Sensor - Right Rear -G77
00776 Level Control System Sensor - Left Front - G78
00777 Throttle Position Sensor -G79
00778 Steering Angle Sensor -G85
00779 Outside Air Temperature Sensor -G17
00780 Vertical Motion Sensor -G90
00781 Positioning Motor - Left Front -V76
00782 Positioning Motor - Right Front - V77
00783 Positioning Motor - Left Front - V78
00784 Positioning Motor - Right Rear -V79
00785 Temperature Sensor -Instrument Panel -G56
00786 Temperature Sensor -in Headliner -G86
00787 Fresh Air Intake Duct Temperature Sensor -G89
00788 Foot Well/defrost Flap Two-wag Valve -N118
00789 Backup Switch -F41
00790 Recirculating/fresh Air Flap
00791 Air Conditioner Evaporator Temperature Switch -G33
00792 Air Conditioner Pressure Switch -F129
00793 Brake Pedal Position Sensor -G100
00794 Hydraulic Pump Sensor -G101
00795 Rear Axle Vertical Acceleration Sensor -G102
00796 Fan for Integer Temperature Sensor -V42
00797 Sunlight Photo Sensor -G107
00798 Segment Test
00799 Engine Coolant Temperature Sensor -G110
00800 Ambient Temperature Sensor Fresh Air Blower -G109
00801 A/C Refrigerant High Pressure Switch -F11b
00802 A/C Refrigerant Low Pressure Switch -F73
00803 Coil Spring Travel Sensor -Right Front - G118
00804 Coil Spring Trawl Sensor -Left Front -G115
00805 Suspension Strut Valve -Left Front - N148
00806 Suspension Strut Valve -Right Front - N149
00807 Suspension Strut Valve -Left Front - N150
00808 Suspension Shut Valve - Right Rear -N151
00811 System Not Ready for Activation
00824 Traction Control Indicator Light -K86
01016 Gas-filled Suspension Bleeder Valve -N106
01017 Gas-filled Suspension System Compressor -V65
01018 Coolant Fan -V7
01019 Relay
01020 Water Pump -V36
01021 Differential Lock Indicator Light -K81
01022 Interior Light -Combination Figure Activated
01023 Warning Buzzer -H3
01025 Malfunction Indicator Lamp Faulty
01027 Rear Warm Air Fan -V47
01028 Fan Relay -J323
01028 Rear Evaporator Fan -V20
01029 A/C Relay -J32
01039 ECT Sensor -G2
01040 ABS/Transmission Electrical Connection 2
01041 Traction Control System -Function Unreadable
01044 P1749 Transmission Control Module -Incorrectly Coded
01045 Tiptronic Switch -F189
01046 Broke Pod Wear Indicator Light -L32
01047 Brake and Parking Brake Warning Light -Kt
01048 Diesel Electronic Warning Light -K104
01049 Supply Voltage (Terminal 50)
01050 Glow Plug Status Monitoring
01051 Fuel MC Positioning Motor -V117
01052 Throttle Position Sensor -G157
01053 Injection Start-valve -N182
01054 Power Supply Relay (Terminal 30) -J317
01055 Injection Start-sensor -G158
01057 Function - Constant Charge - Voltage
01058 Function - Constant Charge - Current
01059 Rotor Position Sensor -G159
01060 Ignition Coil Lower Temperature Sensor -G160
01061 gnition Coil Upper Temperature Sensor -G161
01070 Starter Relay -J53
01071 Clutch Pedal Position Sensor -G162
01072 Clutch Position - Vacuum Valve -N183
01073 Clutch Pressure System
01074 Clutch Position - Vent Valve
01075 Vacuum Pump Relay -J320
01076 Hydraulic Pump Clutch Relay -J319
01077 Brake Booster Vacuum Switch -F190
01078 TR Gear Selector Switch -F191
01079 Power Steering Relay -J320
01080 Power Steering Pressure Switch -F192
01081 Priority Switch Valve -N185
01082 Low Fuel Level Warning Light -K105
01083 Low Windshield Fluid -Windshield Fluid Indicator Light or Sensor -K106
01084 32oF (0o) Freeze Temperature Warning Light -K107
01085 39oF (4o) Temperature Warning Light -K108
01086 Speedometer - Vehicle Speed Sensor -G22
01087 Basic Setting Not Performed
01088 Mixture Control Adjustment 2
01089 Tensioning Bow Raised Position Switch -F204
01090 Tensioning Bow Stowed Position Switch -F203
01091 Convertible Top Closed Position Switch -F202
01092 Convertible Top Open Position Switch -F171
01093 Compartment Cover Open Position Switch -F201
01094 Compartment Cover Left Switch 3-F195
01095 Compartment Cover Unlocked Left Switch 2-F197
01096 Comportment Cover Locked Left Switch 1-F199
01097 Convertible Top Front Lock Switch -F172
01098 Trunk Lid Closed Position Switch -F206
01099 Luggage Compartment Switch (Locked)
01100 Luggage Compartment Switch (Unlocked)
01101 Convertible Top Latch Open Position Switch -F205
01102 Compartment Cover Right Switch 3-F196
01103 Compartment Cover Unlocked Right Switch 2-F198
01104 Compartment Cover Locked Right Switch 1-F200
01105 Solenoid Valve 8-N186
01106 Power Window Opening Relay -J291
01107 Convertible Top Locked Indicator Light -K98
01108 Power Window Closing Relay -J292
01109 Convertible Top Hydraulic Pump Relay -J321
01110 Convertible Top Unlocking Solenoid -N187
01111 Luggage Compartment Lock Actuator Motor 1
01112 Actuator Motor 1 and 2 Power Supply
01113 Luggage Compartment Lock Actuator Motor 2
01114 Parking Brake Warning Light Switch -F9
01115 Just 3 Byte Space
01116 Convertible Top Unlocking Actuator Motor
01117 Generator Terminal DF Load Signal
01118 Engine Pre-heating Circuit
01119 Transmission Shift-Range Gear Position Signal
01120 Camshaft Adjustment 1
01121 Camshaft Adjustment 2
01122 Camshaft Position Sensor 2-G163
01123 Triggering Faulty
01124 Charge Time Status Monitoring
01125 Intake Manifold Change-over
01126 Engine Speed Signal
01127 Reserve Fuel Indicating Lamp
01128 Anti-theft System -Immobilizer Sensor -D2
01129 S-terminal -H15
01130 ABS Operation - Signal outside range of tolerance
01131 Blinking Light Activation
01132 Front Infrared Sensor -G166
01133 Rear Infrared Sensor -G167
01134 Alarm Horn -12
01135 Vehicle Interior-motion Sensor
01136 Engine Start Interrupt
01137 Central Locking Contact Switch
01138 Central Locking - Drivers Door Unlock
01139 Central Locking - Passenger Door Unlock
01140 Central Locking - Trunk Lid Unlock
01141 Trunk Lid Release Switch Motor
01142 Central Locking - Unlocking Motor
01143 Central Locking - Opening Motor
01144 Central Locking - Opening Motor
01145 Central Locking - Opening Motor
01146 Central Locking - Closing Motor
01147 Central Locking - Trunk Lid Release Motor -V120
01148 Save Fuse Door - Activation
01149 Save Fuse Door - Deactivating
01150 Analog Indicator
01151 Diesel Engine Safety Switch -F207
01152 TR Gear Monitoring Switch -F209
01153 E-(Economic) Switch - E163
01154 Clutch System Pressure Switch -F210
01155 Clutch, Mechanics
01156 TR Gear Recognition Switch -F208
01157 Alarm Horn Voltage Supply
01158 Turn Signal Voltage Supply
01159 Save Fuse Wiring
01160 Coolant Glow Plug Relay -J325
01165 Throttle Body Control Module -J338
01166 Engine Torque Signal
01167 Wide Open Throttle Stop - Throttle Stop Valve -N194
01168 Idle Rpm Increase Valve -N177
01169 Door Contact Switch - Driver Side -F2
01170 Fuel Injection Duration Sensor -G175
01172 Seat Heating Temperature Sensor -Driver Side -G59
01173 Longitudinal Adjustment Motor -Driver Side -V28
01174 Height Seat Adjustment - Driver Side -V38
01175 Heated Seat Adjustment - Driver Side - E94
01176 Key Faulty
01177 Engine Control Unit
01179 Incorrect Key Entry
01180 Engine / A/C - Electrical Connection
01181 Initializing - Only 2 Keys Pressed
01182 Height Adaptation
01183 Catalytic Convertor Warning Lamp -K72
01184 Outlet Temperature Sensor -G174
01185 Fresh Air Blower - Rear -V80
01186 Rear Air Distribution Servo Motor -V136
01187 Rear Temperature Flap Servo Motor -V137
01188 Control Module Solenoid - Electrical Connector
01190 Control Module Actuator Motor - Electrical Connector
01192 Torque Converter Clutch
01193 Low Heat Output -J359
01194 High Heat Output -J360
01196 Engine/Transmission Can Bus
01197 Engine/Transmission Can Bus -Wire-A
01198 Engine/Transmission Can Bus -Wire-B
01199 Engine/ABS Electrical Connection
01200 ABS Valves Voltage Supply -Fuse S54
01201 ABS Pump Voltage Supply -Fuse S53
01202 Diagnostic Wire
01208 Data Record Changes -VIN
01235 Secondary Air Injection - Solenoid Valve -N112
01236 Shift-Lock Solenoid -N110
01237 Fuel Cut-off Valve -N109
01238 Ignition Timing (Spark Angle) Control
01239 Throttle Position Actuator Vent Valve -N97
01240 Throttle Position Actuator Breather Valve -N117
01241 EVAP Canister Purge Solenoid Valve -N115
01242 Final Stage in Control Unit
01243 Intake Manifold Change-over Valve -Nix
01244 Heating Oxygen Sensor Control Module -J208
01245 Differential Pressure Regulator -N73
01246 Early Fuel Evaporation Relay -J81
01247 EVAP Canister Purge Regulator Valve -N80
01248 Wide Open Throttle Enrichment Two-way Valve -N54
01249 P0201 Cylinder 1 - Injector Fault -N30
01250 P0202 Cylinder 2 - Injector Fault -N31
01251 P0203 Cylinder 3 - Injector Fault -N32
01252 P0204 Cylinder 4 - Injector Fault -N33
01253 P0205 Cylinder 5 - Injector Fault -N83
01254 P0206 Cylinder 6 - Injector Fault -N84
01255 P0207 Cylinder 7 - Injector Fault -N85
01256 P0208 Cylinder 8 - Injector Fault -N86
01257 Idle Air Control Valve -N71
01258 Air Flap Positioner -V63
01259 Fuel Pump Relay Circuit -J17
01260 Deceleration Fuel Cut-off Valve -N55
01261 Oxygen Sensor Frequency Valve -N7
01262 Wastage Bypass Regulator Valve -N75
01263 Cold Start Injector -N17
01264 Secondary Air Injection Pump Relay -J299
01265 EGR Vacuum Regulator Solenoid Valve -N18
01266 Glow Plug Relay -J52
01267 Automatic Glow Time Control Unit -J179
01268 Quantity Adjuster -N146
01269 Injection Start Valve -N108
01270 A/C Compressor Clutch -N25
01271 Temperature Regulator Flap Motor -V68
01272 Central Air Flap Motor -V70
01273 Fresh Air Blower - V2
01274 Air Flow Flap Motor -V71
01275 Solenoid Relay
01276 ABS Hydraulic Pump - V64
01277 ABS Hydraulic Pump Relay -J185
01278 Electronic Differential Lock Cut-off Relay -J263
16486 P0102 Mass or Volume Air Flow Circuit - Low input
16487 P0103 Mass or Volume Air Flow Circuit - High Input. May be due to a low battery if found with 17988 (P1580)
16496 P0112 IAT Sensor - Temp High -Circuit Low - G42
16497 P0113 IAT Sensor - Temp Low - Circuit High - G42
16500 P0116 Engine Coolant Temperature Circuit -Range/Performance Problem
16501 P0117 Engine Coolant Temperature Circuit -Low Input (High Temp)
16502 P0118 Engine Coolant Temperature Circuit -High Input (Low Temp)
16504 P0120 Throttle Position Sensor A -Circuit Malfunction
16505 P0121 Throttle Position Sensor A -Circuit - Performance Problem -Out of Range
16506 P0122 Throttle Position Sensor A Circuit -Low Voltage Input
16507 P0123 Throttle Position Sensor A Circuit -High Voltage Input
16509 P0125 Cooling System -Temp Too Low to Enter Closed Loop - G62
16514 P0130 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 1)
16515 P0131 O2 Sensor Circuit - Voltage Low (Bank 1 Sensor 1)
16516 P0132 O2 Sensor Circuit - High Voltage (Bank 1 Sensor 1)
16517 P0133 O2 Sensor Circuit - Slow Response (Bank 1 Sensor 1)
16518 P0134 O2 Sensor Circuit - No Activity Detected (Bank 1 Sensor 1)
16519 P0135 O2 Sensor Heater Circuit -Malfunction (Bank 1 Sensor 1)
16520 P0136 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 2)
16521 P0137 O2 Sensor Circuit - Low Voltage (Bank 1 Sensor 2)
16522 P0138 O2 Sensor Circuit - High Voltage (Bank 1 Sensor 2)
16524 P0140 O2 Sensor Circuit - Slow Response (Bank 1 Sensor 2)
16525 P0141 O2 Sensor Heater Circuit -Malfunction (Bank 1 Sensor 2)
16534 P0150 O2 Sensor Circuit - Malfunction (Bank 2 Sensor 1)
16536 P0152 O2 Sensor Circuit - High Voltage (Bank 2 Sensor 1)
16537 P0153 O2 Sensor Circuit - Slow Response (Bank 2 Sensor 1)
16538 P0154 O2 Sensor Circuit - No Activity Detected (Bank 2 Sensor 1)
16539 P0155 O2 Sensor Heater Circuit -Malfunction (Bank 2 Sensor 1)
16540 P0156 O2 Sensor Circuit - Malfunction (Bank 2 Sensor 2)
16542 P0158 O2 Sensor Circuit - High Voltage (Bank 2 Sensor 2)
16543 P0159 O2 Sensor Circuit - Slow Response (Bank 2 Sensor 2)
16544 P0160 O2 Sensor Circuit - No Activity Detected (Bank 2 Sensor 2)
16545 P0161 O2 Sensor Heater Circuit -Malfunction (Bank 2 Sensor 2)
16554 P0170 Fuel Trim -Malfunction (Bank 1)
16555 P0171 Fuel Trim -System Lean (Bank 1)
16556 P0172 Fuel Trim -System Rich (Bank 1)
16557 P0173 Fuel Trim -Malfunction (Bank 2)
16558 P0174 Fuel Trim -System Lean (Bank 2)
16559 P0175 Fuel Trim -System Rich (Bank 2)
16684 P0300 Random Misfire Detected -Any Cylinder
16685 P0301 Cylinder #1 -Misfire Detected
16686 P0302 Cylinder #2 -Misfire Detected
16687 P0303 Cylinder #3 -Misfire Detected
16688 P0304 Cylinder #4 -Misfire Detected
16689 P0305 Cylinder #5 -Misfire Detected
16690 P0306 Cylinder #6 -Misfire Detected
16691 P0307 Cylinder #7 -Misfire Detected
16692 P0308 Cylinder #8 -Misfire Detected
16706 P0322 Ignition/Distributor Engine Speed Input Circuit - No Signal
16711 P0327 Knock Sensor #1 Circuit - Low Input (Bank 1 or Single Sensor)
16716 P0332 Knock Sensor #2 Circuit - Low Input (Bank 2)
16721 P0337 Crankshaft Position Sensor Circuit - Low Input
16725 P0341 Camshaft Position Sensor Circuit - Out of Range/Performance
16784 P0400 Exhaust Gas Recirculation (EGR) -Flow Malfunction
16785 P0401 Exhaust Gas Recirculation (EGR) -Flow Insufficient
16786 P0402 Exhaust Gas Recirculation (EGR) -Flow Excessive
16795 P0411 Secondary Air Injection System (B2) - Incorrect Flow
16806 P0422 Main Catalyst Efficiency - Below Threshold (Bank 1)
16816 P0432 Main Catalyst Efficiency - Below Threshold (Bank 2)
16824 P0440 Evaporative Emission Control System (EVAP) -Purge Malfunction
16825 P0441 Evaporative Emission Control System -Incorrect Purge Flow
16826 P0442 Evaporative Emission Control System -Leak Detected (small leak)
16836 P0452 Evaporative Emission Control System -Pressure Sensor - Low Input
16837 P0453 Evaporative Emission Control System -Pressure Sensor - High Input
16839 P0455 Evaporative Emission Control System -Leak Detected (gross leak)
16845 P0461 Fuel Level Sensor Circuit - Range/Performance
16885 P0501 Vehicle Speed Sensor -Range/Performance
16890 P0506 Idle Control Module - RPM Lower Than Expected
16891 P0507 Idle Control Module - RPM Higher Than Expected
16894 P0510 Throttle Position Sensor -Closed Switch
16989 P0605 Internal Control Module Read Only Memory (EPROM) Error
17090 P0706 Transmission Range Sensor Circuit -Range/Performance
17091 P0707 Transmission Range Sensor Circuit -Low Input
17509 P1101 O2 Sensor Circuit (B1-S1) Voltage Too Low/Air Leak
17510 P1102 O2 Sensor Circuit Heating Circuit (B1-S1) -Short to B+
17511 P1103 O2 Sensor Circuit Heating Circuit (B1-S1) -Output Too Low
17512 P1104 O2 Sensor Circuit (B1-S2) Voltage Too Low - Air Leak
17513 P1105 O2 Sensor Circuit Heating Circuit (B1-S2) -Short to B+
17514 P1106 O2 Sensor Circuit (B2-S1) Voltage Too Low - Air Leak
17515 P1107 O2 Sensor Circuit Heating Circuit (B2-S1) -Short to B+
17516 P1108 O2 Sensor Circuit Heating Circuit (B2-S1) -Output too Low
17517 P1109 O2 Sensor Circuit (B2-S2) Voltage Too Low - Air Leak
17518 P1110 O2 Sensor Circuit Heating Circuit (B2-S2) -Short to B+
17535 P1127 Long Term Fuel Trim -System too Rich (Bank 1)
17536 P1128 Long Term Fuel Trim -System too Lean (Bank 1)
17609 P1201 Cylinder #1 Fuel Injector Circuit - Electrical Malfunction
17610 P1202 Cylinder #2 Fuel Injector Circuit - Electrical Malfunction
17611 P1203 Cylinder #3 Fuel Injector Circuit - Electrical Malfunction
17612 P1204 Cylinder #4 Fuel Injector Circuit - Electrical Malfunction
17613 P1205 Cylinder #5 Fuel Injector Circuit - Electrical Malfunction
17614 P1206 Cylinder #6 Fuel Injector Circuit - Electrical Malfunction
17615 P1207 Cylinder #7 Fuel Injector Circuit - Electrical Malfunction
17616 P1208 Cylinder #8 Fuel Injector Circuit - Electrical Malfunction
17621 P1213 Cylinder #1 Fuel Injector Circuit - Short to B+
17622 P1214 Cylinder #2 Fuel Injector Circuit - Short to B+
17623 P1215 Cylinder #3 Fuel Injector Circuit - Short to B+
17624 P1216 Cylinder #4 Fuel Injector Circuit - Short to B+
17625 P1217 Cylinder #5 Fuel Injector Circuit - Short to B+
17626 P1218 Cylinder #6 Fuel Injector Circuit - Shod to B+
17627 P1219 Cylinder #7 Fuel Injector Circuit - Shod to B+
17628 P1220 Cylinder #8 Fuel Injector Circuit - Shod to B+
17633 P1225 Cylinder #1 Fuel Injector Circuit - Short to Ground
17634 P1226 Cylinder #2 Fuel Injector Circuit - Short to Ground
17635 P1227 Cylinder #3 Fuel Injector Circuit - Short to Ground
17636 P1228 Cylinder #4 Fuel Injector Circuit - Short to Ground
17637 P1229 Cylinder #5 Fuel Injector Circuit - Short to Ground
17638 P1230 Cylinder #6 Fuel Injector Circuit - Short to Ground
17639 P1231 Cylinder #7 Fuel Injector Circuit - Short to Ground
17640 P1232 Cylinder #8 Fuel Injector Circuit - Short to Ground
17645 P1237 Cylinder #1 Fuel Injector Circuit - Open Circuit
17646 P1238 Cylinder #2 Fuel Injector Circuit - Open Circuit
17647 P1239 Cylinder #3 Fuel Injector Circuit - Open Circuit
17648 P1240 Cylinder #4 Fuel Injector Circuit - Open Circuit
17649 P1241 Cylinder #5 Fuel Injector Circuit - Open Circuit
17650 P1242 Cylinder #6 Fuel Injector Circuit - Open Circuit
17651 P1243 Cylinder #7 Fuel Injector Circuit - Open Circuit
17652 P1244 Cylinder #8 Fuel Injector Circuit - Open Circuit
17656 P1250 Fuel Level Too Low
17733 P1325 Cylinder #1 Knock Control Limit Attained
17734 P1326 Cylinder #2 Knock Control Limit Attained
17735 P1327 Cylinder #3 Knock Control Limit Attained
17736 P1328 Cylinder #4 Knock Control Limit Attained
17737 P1329 Cylinder #5 Knock Control Limit Attained
17738 P1330 Cylinder #6 Knock Control Limit Attained
17739 P1331 Cylinder #7 Knock Control Limit Attained
17740 P1332 Cylinder #8 Knock Control Limit Attained
17747 P1339 Crankshaft Position/Engine Speed Sensors Cross connected
17748 P1340 Camshaft/Crankshaft Position Sensors (B2) -Out of Sequence
17749 P1341 Ignition Coil Power Output Stage #1 -Short to Ground
17751 P1343 Ignition Coil Power Output Stage #2 -Short to Ground
17753 P1345 Ignition Coil Power Output Stage #3 -Short to Ground
17799 P1391 Camshaft Position Sensor (B2) -Short to Ground
17800 P1392 Camshaft Position Sensor Open (B2) - Short to B+
17801 P1393 Ignition Coil Power Output Stage #1 -Electrical Malfunction
17802 P1394 Ignition Coil Power Output Stage #2 -Electrical Malfunction
17803 P1395 Ignition Coil Power Output Stage #3 -Electrical Malfunction
17804 P1396 Engine Speed Sensor -Missing Tooth
17808 P1400 EGR Valve Circuit - Electrical Malfunction
17809 P1401 EGR Valve Circuit - Power Stage Short to Ground
17810 P1402 EGR Valve Circuit - Short to B+
17815 P1407 EGR Temperature Sensor -Signal too Low
17816 P1408 EGR Temperature Sensor -Signal too High
17817 P1409 Tank Ventilation Valve - Electrical Malfunction
17818 P1410 Tank Ventilation Valve - Short to B+
17819 P1411 Secondary Air Injection System (B2) - Restricted Flow
17822 P1414 Secondary Air Injection System (B2) - Leak Detected
17826 P1418 Fuel Level Sensor -Signal too High
17828 P1420 Secondary Air Injection System Control Module -Electrical Malfunction
17829 P1421 Secondary Air Injection System Control Valve Circuit - Short to Ground
17830 P1422 Secondary Air Injection System Control Valve Circuit - Short to B+
17831 P1423 Secondary Air Injection System (B1) - Flow too Low
17832 P1424 Secondary Air Injection System (B1) - Leak Detected
17833 P1425 Tank Ventilation Valve - Short to Ground
17834 P1426 Tank Ventilation Valve - Open Circuit
17842 P1434 Secondary Air Injection System Pump Relay Circuit - Short to B+
17844 P1436 Secondary Air Injection System Pump Relay Circuit - Electrical Malfunction
17848 P1440 EGR Valve Circuit - Power Stage Open
17858 P1450 Secondary Air Injection System Pump Relay Circuit - Short to B+
17859 P1451 Secondary Air Injection System Pump Relay Circuit - Short to Ground
17860 P1452 Secondary Air Injection System Pump Relay Circuit - Open Circuit
17878 P1470 EVAP Emission Control System L.D.P Circuit -Malfunction
17879 P1471 EVAP Emission Control System L.D.P. Circuit - Short to B+
17883 P1475 EVAP Emission Control System L.D.P. - Malfunction Signal Circuit open
17884 P1476 EVAP Emission Control System L.D.P. - Malfunction/Insufficient Vacuum
17908 P1500 Fuel Pump Relay Circuit - Electrical Malfunction
17910 P1502 Fuel Pump Relay Circuit - Short to B+
17912 P1504 Intake Air System Bypass Air Determined
17913 P1505 CTP Switch not Closing -Open Circuit
17914 P1506 CTP Switch not Opening -Short to Ground
17917 P1509 IAC Circuit -Electrical Malfunction
17918 P1510 IAC Circuit -Short to B+
17919 P1511 Intake Manifold Changeover Valve Circuit -Electrical Malfunction
17920 P1512 Intake Manifold Changeover Valve Circuit -Short to B+
17951 P1543 Throttle Actuation Potentiometer -Signal too Low
17952 P1544 Throttle Actuation Potentiometer -Signal too High
P1545
P1559
17988 P1580 Throttle Actuator (B1) Fault - May be caused by low battery if found with 16487 (P0103)
17990 P1582 Idle Adaption at Limit
18008 P1600 Power Supply (B+) Terminal 15 -Low Voltage
18010 P1602 Power Supply (B+) Terminal 30 -Low Voltage
18014 P1606 Rough Road Spec. Engine Torque ABS-SG - Electrical Malfunction
18019 P1611 MIL Call-up Circuit/Transmission Control Module - Short to Ground
18020 P1612 ECM - Incorrectly Coded
18021 P1613 MIL Call-up -Circuit Open or Short to B+
65535 P0603 Control Unit Failure or Internal Control Module Keep Alive Memory (KAM) Error or Power Failure to Control Unit or Bad Ground Contacts or No Faults Recorded (If MIL Not Illuminated)
65535 Control Unit Faulty (In Some Systems)
P0217 Temp Light -Engine Hot
P0218 Temp Light -Transaxle Hot
P0326 Knock Sensor - Constant Knock
P0351 Ignition -Faulty
P0352 Ignition -Faulty
P0420 Converter -Low Efficiency
P0443 EVAP Purge - Circuit Fault
P0500 VSS Sensor - No Signal
P0560 Battery Voltage - Out of Range
P0561 Battery Voltage - Unstable
P0562 Battery Voltage - Low
P0563 Battery Voltage - High
P0565 Cruise Control -Circuit Fault
P0571 Brake Switch -Circuit Fault
P0572 Brake Switch -Low Voltage
P0573 Brake Switch -High Voltage
P0600 PCM -No Serial Data
P0601 EPROM - Fault
P0602 PCM Program - Fault
P0604 PCM RAM Memory -Fault
P0606 PCM Processor - Fault
P1782 Engine/Transmission Data Electrical Connection Ignition Intervention. Also check for loose ECM power relay.
bu sitede biraz bilgi var ama bende ingilizce yok
http://wiki.ross-tech.com/wiki/index.php/Main_Page
