75.2 modeli [TABLE="width: 0, align: center"]
[TR="class: tdCarDet"]
[TD]General[/TD]
[TD] [/TD]
[/TR]
[TD]Power Output[/TD]
[TD]97 Watts RMS x 2 channels at 4 ohms and ≤ 1% THD + N
145 Watts RMS x 2 channels at 2 ohms, 14.4V supply and ≤ 1% THD + N
290 Watts RMS x 1 channel at 4 ohms, 14.4V supply and ≤ 1% THD + N[/TD]
[/TR]
[TD]Signal-to-Noise Ratio[/TD]
[TD]Signal-to-noise ratio: 82dBA (reference 1 watt into 4 ohms)[/TD]
[/TR]
[TD]Dynamic Power[/TD]
[TD]190 watts at 2 ohms[/TD]
[/TR]
[TD]Effective damping factor[/TD]
[TD]6.39 at 4 ohms[/TD]
[/TR]
[TD]Frequency Response[/TD]
[TD]10Hz – 90kHz (–3dB)[/TD]
[/TR]
[TD]Maximum input signal[/TD]
[TD]5.5V[/TD]
[/TR]
[TD]Maximum sensitivity[/TD]
[TD]230mV[/TD]
[/TR]
[TD]Output regulation[/TD]
[TD]0.098dB at 4 ohms[/TD]
[/TR]
[TD] [/TD]
[TD]12dB Built-in, variable, low-pass electronic crossover[/TD]
[/TR]
[TD] [/TD]
[TD]One pair full-range preamp outputs[/TD]
[/TR]
[TD] [/TD]
[TD]Separate high-level and low-level inputs[/TD]
[/TR]
[TR="class: tdCar2"]
[TD]Dimensions (H x W x D)[/TD]
[TD]295mm x 313mm x[/TD]
[/TR]
[/TABLE]
