bir başka IBIZA CUPRA
veriler için aynı fakat 200 kg daha hafif diyor..
diğerleri aşağıda tercümeyi size bıraktım
The license for the competition on the race track has the new Seat Ibiza SC Trophy. For the propulsion of the small racer makes the 180-hp engine from the Ibiza Cupra, the 7-speed DSG transmission is shifted as the production model at the wheel.
An exclusive front design gives the racer an aggressive character, by the “Arrow Design” fails with its arranged around the central grille air intakes, particularly aggressive. At the rear, also a mounted spoiler ensures the necessary down force during cornering.
The performance data of only 1063 kg heavy Seat Ibiza SC Tropy gave the Spaniard unfortunately unknown. By comparison, the standard Ibiza Cupra accelerates with the same engine and also 180 hp in 7.2 seconds from zero to 100 and ended its driving at 225 km / h. There is one major difference: The Cup car is around 200 kilograms lighter.
In order to control the forces properly, the brake system of the Seat Leon Cupra is used. Sun discs packed with a diameter of 345 millimeters and 288 millimeters in the front right to rear. Compared to the production model enlarged seat the wheelbase of Cup racing car to 13 mm, the front track to 170 mm and the rear track to 29 mm – measures which provide for an increased resistance and at the same time the design further stress.
At the same time, the Cup car is lowered by 40 millimeters. The track and the camber can be adjusted individually. Contact with the asphalt to keep the Seat Ibiza SC Trophy 17-inch wheels, wider wheel arches, which are among prominent place. For the high lateral acceleration forces in racing conditions, which enables the optimized chassis, the engine also received a modified oil pan.
Related posts:
Yarış pisti yarışma için lisans yeni Seat Ibiza SC Trophy vardır. Küçük yarışçı tahrik için yapar Ibiza Cupra, 180 hp motor, 7 ileri DSG şanzıman, direksiyon başında üretim modeli olarak kaydırılır.
Özellikle agresif merkezi ızgarası, hava girişleri, etrafında düzenlenmiş özel bir ön tasarım başarısız "Ok Tasarım", yarışçı, saldırgan bir karakter verir. Arka kısımda, ayrıca bağlanmış bir spoyler viraj alma sırasında gerekli aşağı kuvvet sağlar.
Sadece 1063 kg ağır Seat Ibiza SC Tropy performans verileri maalesef bilinmiyor İspanyol verdi. Karşılaştırma yapmak gerekirse, standart Ibiza Cupra, aynı motor ve 7.2 saniyede sıfırdan 100 de 180 hp ve 225 km / h hızda sürüş sona erdi hızlandırır Önemli bir fark vardır: Kupası arabanın etrafında 200 kilogram daha hafif.
Güçleri kontrol altında tutmak için, Seat Leon Cupra, fren sistemi kullanılır. Sun diskleri, ön sağ arka çapı 345 milimetre ve 288 milimetre dolu. Bir direnç ve aynı zamanda tasarım daha fazla stres sağlayan önlemler - 170 mm'ye kadar üretim modeli büyütülmüş koltuk Cup yarış otomobili 13 mm dingil mesafesi, ön parça ve arka iz genişliği 29 mm ile karşılaştırıldığında.
Aynı zamanda Kupası araba 40 milimetre alçaltılmış. Izlemek ve kamber ayrı ayrı ayarlanabilmektedir. Önemli bir yere arasındadır Seat Ibiza SC Trophy 17-inç jantlar, geniş çamurluklar, tutmak için asfalt ile temasa geçin. Optimize edilmiş şasiye sağlayan yarış koşulları, yüksek yanal ivme güçleri, motor modifiye edilmiş bir yağ tavasına aldı.
DEMİŞ
DEMİŞ
ömür adamsın vesselam
ALLAH senden razı olsun
Dandik araç, her yerinden ses geliyo. Ben öyle duydum :D
Güzel olmuş ama bu tarz body kit hangi araca yakışmıyor ki.
xx
